You can change user names for default users (rwa, rw, and ro) for the specified access level. You cannot change user names for user-defined users.
Only the rwa user can change the default user name.
Perform this procedure to change the default user name for the specified access level.
Change the default user name for the RO access to CLI:
Switch:1>enable Switch:1#config t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#username EXUser level ro Do you want to change username for the default RO user ? (y/n) ? y Enter the old password : ** Enter the New password : ***** Re-enter the New password : *****
The following table defines parameters for the username command.
| Variable | Value |
| WORD<1-20> | Specifies the user logon name. |
| level l1|l2|l3|ro|rw|rwa | Specifies the access level. |
